Našel jsem na netu parametry astry g opc a to jak verze hatchback tak i caravan, tak vám toto také nabízím k nahlédnutí.
Myslím že nejeden z nás bychom je rádi měli v garáži 😉
2003 Opel Astra OPC |
Specifications |
Engine Type |
2.0 Liter Turbo Ecotec Inline 4 |
Displacement cu in (cc) |
1998 cc / 121.9 cu in |
Power bhp (kW) at RPM |
149.1 kW / 200.0 bhp at 5600 rpm |
Torque lb-ft (Nm) at RPM |
250.0 Nm / 184.4 ft lbs at 1950 rpm |
Redline at RPM |
n.a. |
Brakes |
Dual-Circuit Brake System w/ Vented Front. Solid rear Discs |
Tires |
215/40ZR-17 |
Length |
4110 mm / 161.8 in |
Weight |
1250 kg / 2756 lbs |
Acceleration 0-62 mphs |
7.5 seconds |
Top Speed mph (km/h) |
240.0 kph / 149.1 mph |
2003 Opel Astra OPC Station Wagon |
Specifications |
Engine Type |
Redline at RPM |
n.a. |
Brakes |
Tires |
215/45ZR-17 |
Length |
4288 mm / 168.8 in |
Weight |
1340 kg / 2954 lbs |
7.8 seconds |
231.0 kph / 143.5 mph |
Související:
