Udrelo mi tam do oci to, co je cervenym vo vypise... je to datum progamovania RJ???? 12.02.2015??? Menena???
- OP-COM 081016 - PC based diagnostic tool
Date and time>,08/04/2015. 17:20
Workshop information:
Please add your workshop
name in the settings
window
Selected model>,2003,Zafira,Engine,Y 20 DTH
Control Unit:
Keyword #1: EF
Keyword #2: 8F
Normal timing parameter set.
VIN: W0L0TGF753204XXXX
vehicleManufacturerECUHardwareNumber 09202063 KC
systemSupplierECUHardwareNumber: BOSCH010000001401
systemSupplierECUHardwareVersionNumber: 0000
systemSupplierECUSoftwareNumber: 6MAM1050_S
systemSupplierECUSoftwareVersionNumber: 06AA
exhaustRegulationOrTypeApprovalNumber: B02005
systemNameOrEngineType: Y20DTH
RepairShopCodeOrTesterSerialNumber: O200005197
ProgrammingDate: 20150212
Identifier: 1410
VehicleManufacturerSpecific: 0470504203
Measuring blocks information:
Battery Voltage,13.9 V
Ignition Status,On 12V
APP at Idle Position (Accelerator Pedal Position),Active
APP Sensor 1 (Accelerator Pedal Position),0.97 V
APP Sensor 2 (Accelerator Pedal Position),0.48 V
Calculated Pedal Position,0 %
Barometric Pressure,99 kPa
Barometric Pressure,4.09 V
Boost Pressure Command,112 kPa
Boost Pressure,99 kPa
Boost Pressure,1.61 V
Mass Air Flow Sensor,295 mg/strk
Mass Air Flow Sensor,1.74 V
Intake Air Temperature,17 °C
Intake Air Temperature,2.76 V
Coolant Temperature,49 °C
Coolant Temperature,2.30 V
Engine Oil Temperature,44 °C
Engine Oil Temperature,3.56 V
Fuel Temperature,37 °C
Brake Switch 1,Inactive
Brake Switch 2,Inactive 12V
Desired Engine Idle Speed,800 RPM
Engine Speed,800 RPM
Injection Pump Speed,400.23 RPM
Desired Injection Start,1.8 °CA
Actual Injection Start,1.8 °CA
Actual Injection Quantity,6.0 mg/strk
A/C Information Switch,Inactive
A/C Relay (Air Conditioning),Active
A/C Load Signal (Air Conditioning),16 %
A/C Pressure (Air Conditioning),419 kPa
EGR Valve (Exhaust-Gas Recirculation),Active
EGR Position Command (Exhaust- Gas Recirculation),40 %
EGR Pulse Ratio (Exhaust Gas Recirculation),41 %
EGR Feedback (Exhaust Gas Recirculation),Incorrect
Pulse Ratio Boost Pressure Solenoid Valve,56 %
Swirl Level Control Solenoid Valve Pulse Ratio,4 %
Pulse Ratio Throttle Control Solenoid Valve,5 %
Outside Temperature Sensor_,9 °C
Outside Temperature Sensor_,2.51 V
Glow Time Relay,Active 0V
Diagnosis Glow Time Relay,Inactive
Glow Time Telltale,Off
Malfunction Indicator (MI),Off
Service Vehicle Soon (SVS) Indicator,ON
Vehicle Speed,0 km/h
Clutch Switch,Inactive
Cruise Control Tip Switch,Invalid
Vehicle Speed in Cruise Control Range,Inactive
Immobiliser Function Programmed,- - -
Security Wait Time,- - -
